Intermittent strange behavior
Old Jun 8, 2021 | 06:07 PM
Test is free, won’t hurt to test to eliminate the battery and then the charging system.
then you can investigate the under hood fuse box.
Old Jun 9, 2021 | 03:26 PM
twotimers79's Avatar
No Don, we are wrong. . The OP said it can't be the battery/voltage/connection. It MUST be that computer (post #5)
What does "post #5" mean ?
Old Jun 9, 2021 | 05:45 PM
I was referring to what you said in post #5.
(Each comment is called a post. Each numbered in order. The number is at the top right hand corner of the post.)
Old Jun 9, 2021 | 05:46 PM
Originally Posted by twotimers79
It's a 06, big motor, and lots of miles. I realy don't think it's a battery problem, have not had any trouble starting. I was thinking more along the lines of a computer glitch since it seems to "reset" itself after being turned off and key removed. Sometimes it happens again after a couple days, and other times it may be weeks between incedents. Am I totally off in that speculation ?
this is post #5
Sundance
Feb 16, 2014 08:53 AM
Beany
Aug 22, 2012 05:20 PM
tracy waddell
Apr 29, 2011 04:54 PM
trails10
Jun 4, 2010 02:50 AM
tcstoy
Mar 9, 2008 12:50 PM
