internal computer module
Old Jun 23, 2012 | 09:19 AM
Brewer13's Avatar
Anyone have their engine cut out while driving---first the dash says engine power reduced then goes to engine disengaged. Did a scan and it said internal computer module. Anyone know what thats gonna run?
Old Jun 23, 2012 | 09:33 AM
What was the code? Ie: P1224
Old Jun 23, 2012 | 09:35 AM
Well if the ECM has failed you're looking at somewhere between $350-400 for a new one, or around $100 for a used one, plus diagnostics and labor unless you do the work yourself.
What codes are showing up? Also check the underhood fuse box, make sure all the fuses and relays are firmly seated in their respective sockets, plus check the fuse box itself to make sure it isn't loose.
Old Jun 23, 2012 | 09:40 AM
Brewer13's Avatar
OK thanx guys
heatherbrooker
12
Aug 21, 2014 09:07 AM
rick_rob
Oct 21, 2012 09:15 PM
SFBay
Maintenance and Upkeep
Jan 17, 2012 02:45 PM
geg
May 18, 2010 11:17 AM
GDZHHR
Nov 23, 2007 12:09 PM
