jtriker
Old Oct 5, 2013 | 02:42 PM
jtriker's Avatar
Angry jtriker
codes p010 , p011 have 45,000 milage 2 week ago came on but went off , came back on week later went off after 3 key off , 10-4 came on will not go off , run fine had check it gave codes p010 & p011 can someone help
Old Oct 5, 2013 | 03:27 PM
First off, what is the fourth digit of the code. I am taking a guess that you mean P0010 & P0011. Use the full number in the "search box" and you will find lot's of info about the cam position solenoids and sensors.
Old Oct 5, 2013 | 04:21 PM
jtriker's Avatar
thank you
Old Oct 5, 2013 | 07:51 PM
The codes P0010/11 point towards the INTAKE camshaft actuator SOLENOID as being defective and needing replacement. Note it is a SOLENOID not a "sensor"(important). Approximately a $50 part and half an hour of your time to replace it - pretty easy job.
in the HOW-TO section here is a description of how to replace it (looks much more difficult than it really is): https://www.chevyhhr.net/forums/how-tutorial-library-21/camshaft-position-actuator-solenoid-valve-replacement-w-pics-p0010-11-p0013-14-a-28779/
Tip for you - in the title of the thread put a brief description of the problem rather than your name - it will attract more people to the thread. IE: "CEL shows P0010 and P0011 - help". And as Donbrews says, if you have such a code available, give the search tool at the top of the page a try - it often will save you a whole lot of time.
And................. WELCOME!!! Have fun.
Old Oct 6, 2013 | 01:31 PM
And if you need something like your thread title modified or edited after it's been up for a while, just ask one of the Moderators here and we'll glady take care of it.
