just did engine swap. plz help!
Hooked as in hung it there out of the way? Or wiring harness connection to strut tower??
Was the battery connected at this time, did it blow a fuse or circuit breaker when you attempted to engage the starter?
Hooked meaning he thought it was a ground wire and bolted it down and no fuses popped car had no power as that is the main power wire from the battery to the fuse box yes battery was hooked up and positive was grounded to the car chassis
The positive battery cable was hooked to a ground and that didn't burn? If it was connected like you say and every cable/wire is good then I guess the ground from the battery wasn't hooked up.
Post pictures that might help.
CatMan has it correct. For a little FYI. There are 3 positive leads on the passenger side of the fuse box. The one closest to the firewall is for power steering. The 2 bolted together are the main lead from the battery and the starter lead. You should actually be ok, really depends how long it was hooked up. I'd put money on your battery is toast. The main lead is about 4awg it could hold the amps for a few minutes without cooking, the connection points will get very hot first as they have the least amount of conductive surface area. The battery probably swelled excessively and boiled off some of the heat.
How long was it hooked up, and how did you notice the problem?
We'll check for that fusible link for Old Blue first! Do you have a multimeter with a continuity tester? I'm not sure if there's a fusible link between the battery and fuse box, we can check to make sure the cable is ok though. What you'll need;
1. A cheap multimeter with continuity tester(7 Function Multimeter)
2. About 30' of any wire (speaker wire will work, whatever you have handy!)
3. Some electrical tape (any tape really, just a way to attach your wire to the positive lead)
First, disconnect the positive lead from the battery and fuse box. We want it isolated. Next, tape one end of your wire (speaker or whatever, stripped bare) to the positive lead in the trunk. Now run the other end up front close to the fuse box. Set your meter to continuity, touch the + and - together it should beep/ring (whatever) Now we know your meter works, what we are checking is to see if the main positive lead has any breaks or open fuses. Take one of your meter leads and hold it to your Main positive lead. Touch the other meter lead to your cable you have taped to the other end of the main lead. It should beep and then you know your cable isn't burnt in half somewhere under the car.
If you have continuity you probably have no issues other than a dead battery. Lesson learned.
I noticed it as soon as I hoped in the car and attempted to start it I noticed I had no power so I checked the battery and my charger flashed a red light meaning something wrong with the battery so I immediately disconnected the battery and then the charger read the battery at 30% so I knew there was a problem as soon as I went to hook the battery back up it through strong sparks like a mig welder so I traced the wire and realized the wire had been hooked up to the ground and the fuse box was getting no juice...
As for the fuseable link I tested continuity and that fuse is fine as is all the other fuses...
Now I have power to the car the pwr windows work but everything associated with the steering column isn't working no fuel pump priming no swithching on the starter solenoid the controls that shuffle trough the mileage and other stuff in the gauge cluster (dtc)
I'm fairly certain your friend is right. The positive lead runs directly from the battery to the fuse panel under the hood. From there everything gets power from either fuse or relay. The positive lead does branch at the connection point on the side of the fuse box. It runs with the engine harness to the starter solenoid. Also the alternator positive lead is connected here (on the starter solenoid).
So. You said he hooked it up..hooked it up to what? Shorting the positive lead from the battery to any ground will give a few sparks, shouldn't hurt anything. If it was the starter lead that shorted and was tied to the fuse panel that might cause a problem, it didn't for me.. I was removing the engine wiring harness and fuse panel so I could pressure wash the engine bay before reinstalling the engine. Well, I was reminded that I hooked up the battery when sparks went flying from the stater lead as it contacted the freshly wire brushed cradle (uh, whoops!). I forgot I hooked the battery up to unlock the steering wheel so we could push the car outside.
I got lucky, hopefully you'll be the same. Need some more details into what exactly he hooked up to where.
Since you did have your cradle out I have to ask. Is there a chance your steering wheel got spun around more than 2 times? It happened to me like I mentioned before. You didn't say you had a CHECK AIRBAG warning so that doesn't seem to be the problem.
If you want some trouble shooting advice over the phone I could try and help diagnose the situation a little better. PM me for my number.
