Key Fob Low Battery Alert?
Welcome to the site
you may just need to replace the battery in the key fob. We have seen a solder joint have some problems so give this thread a read.
https://www.chevyhhr.net/forums/how-tutorial-library-21/keyfob-cold-solder-repair-22641/
you may just need to replace the battery in the key fob. We have seen a solder joint have some problems so give this thread a read. https://www.chevyhhr.net/forums/how-tutorial-library-21/keyfob-cold-solder-repair-22641/
Replace the battery in the key fob. 2032 if I remember correctly. Use a thin plastic credit or gift card and pry the 2 halves apart. I'm sure there's a tutorial around here if you run a search, but its not difficult at all.
Welcome to the site, replace the battery in the key fob, I used the search window and found this for you , hope it helps!!
www.chevyhhr.net/forums/showthread.php?t=36599
