knock senser code p0325
to the forum!Dang good question really, P0325 is a knock sensor code, do you know if they have cleared the codes after performing the work?
They might have nailed the problem, but the stored code is triggering the CEL. Codes can "self clear" after a period of run cycles, each cycle consisting of an engine start, driving the vehicle, and then a shutdown. But it can take 10-15+ cycles to self clear a stored code.
Your first step should be quizzing the shop on whether they cleared the codes, if they have, then it's time to look at the connector and wiring harness going to the knock sensor.
Welcome to the site
If they changed the sensor twice I would guess that there may be a wiring issue. Some auto techs read the code then replaces the sensor with out doing electrical checks. This works about 70% of the time.
