Lca
Lca
Changed out the right side LCA today. It was factory from 2008!! Yup the bushing was shot. I drilled, ground and pressed the old rivets out and replaced with a TRW balljoint with grade 10.9 12MM bolts, washers and nylocks. Pressed out the old rear bushing with a piece of 3" long pipe turned down to just a hair small ID than the bushing, so I can press it out without getting my tool stuck. Prepping the LCA is a major pain! Now here is where I want your feedback. When I go to torque the rear bushing bolt, I go 74 ft lbs then it calls for another 180 degrees!! I get about 90 degrees and stop, I swear if I go the full 180 that it is literally gonna snap the bolt or booger up that nut that is encapsulated in where ever it lives. Eiither of which is gonna make this job light years worse. Do you guys do the full 180, has any one had issues?
Lca
Yes, that is a torque-to-yield bolt. Any bolt that has to be torqued to a point, then more degrees are added to the tightening is this kind of bolt. For safety reasons, they can only be used once, using them twice can lead to breakage.
Not exactly; TTY bolts stretch so that the threads are deformed to a point they lock in, and can not be reused because they are deformed. Torque to Angle is just a more accurate way of measuring consistent clamping force.
TTY is not exactly the same as TTA. TTY is a type of bolt, TTA is a procedure.
TTY vs. Torque-to-Angle (TTA)
https://www.freeasestudyguides.com/a1_4.html
https://www.felpro.com/technical/tec...tty-bolts.html
https://www.onallcylinders.com/2016/...gle-fastening/
- TTY (Torque-to-Yield): Stretches past the yield point; not reusable.
- TTA (Torque-to-Angle): Stretches within the elastic range; can return to original length and is potentially reusable.
Kookie
41
Oct 13, 2019 11:12 AM
junker
10
Apr 20, 2018 11:10 PM
