Captive nut loose on Subframe Bolt
Old Nov 8, 2021 | 11:44 AM
navaro's Avatar
Unable to get sub-frame bolt out of rear control arm bushing. Appears captive nut is moving. How do I access the captive nut? This is on the passenger side of the vehicle.
this is 2009 HHR
Old Nov 8, 2021 | 11:52 AM
That the easy side! Look up above the bolt from under the car, above the subframe, try a pry bar to wedge into the cage to hold the nut from spinning.
Here’s a photo with the subframe removed, see the cage.
Old Nov 8, 2021 | 03:16 PM
navaro's Avatar
Smile Thank you
The nut was not the problem, it was holding fine. Problem was the metal bushing in the control arm was seized from corrosion, Had to put tons of penetrating oil on the bolt and basically remove all of the rubber from the outside of the bushing so that my vice grips could get a hold on the bushing. Then used my impact wrench to get the bolt loose from the bushing. It came right out as soon as it broke loose. Thank you for the picture it showed me where the nut was and enabled me to rule that part out..
Old Nov 8, 2021 | 03:19 PM
You’re welcome! Glad you got it out! Do you need a new bolt? There’s a part number here, somewhere
cj1clark
Sep 13, 2020 08:55 PM
jarheadbobandmax
Apr 19, 2020 01:31 PM
fonque
Maintenance and Upkeep
Mar 27, 2017 09:52 AM
crocitto49
Oct 1, 2013 06:57 PM
minnesotahhr
Jul 7, 2013 02:25 PM
