Lower control arm body mount bolt and cage nut
Old Jun 27, 2019 | 09:49 PM
cj1clark's Avatar
Question Lower control arm body mount bolt and cage nut
Hi I have a 2010 HHR, I’m looking for a part number for the Lower control arm body mount bolt and cage nut. Is this dealer only? Or is there a kit? I know I’m able to get the bolt at dealer but haven’t found the cage nut anywhere. Thank you
Old Jun 28, 2019 | 07:48 AM
Welcome to the site, the cage nut wasn’t a service part . You’ll have to improvise.
some threads
https://www.google.ca/search?q=HHR+l...&client=safari
Old Sep 13, 2020 | 03:38 PM
winkybill's Avatar
It might have been a captive nut that needed to be replaced because it was cross threaded. It's not like I know this because of experience.
Kodi nox
Old Sep 13, 2020 | 06:28 PM
I just dealt with the cage nut spinning in the cage on the drivers side.
After removing the steering rack from the drivers side , then the front swaybar removed from the passenger side, I could get a pair of 10” vise grips with the jaws wide open to squeeze the nut and hold it tight enough to remove the bolt . In here , post #112
https://www.chevyhhr.net/forums/www....age=12&t=62087
Old Sep 13, 2020 | 08:55 PM
hellshotrod's Avatar
if u need the bolt and nut lmk , free just cover the s/h i have rust free orig thanks dave and crystal
HHRnovice
Jul 23, 2020 06:06 PM
puckdude40
May 7, 2020 06:47 PM
jarheadbobandmax
Apr 19, 2020 01:31 PM
Kookie
41
Oct 13, 2019 11:12 AM
crocitto49
Oct 1, 2013 06:57 PM
