Leak on my tank
Old Mar 21, 2015 | 08:20 PM
slanwar's Avatar
Leak on my tank
I have a leak somewhere on my tank, leaves a small pool of gas when I park on drivers side, I removed the tank but I can't see where is the leak, any ideas how to check the tank for leaks?
Old Mar 21, 2015 | 08:57 PM
slanwar's Avatar
I forgot to add on my previous post but doesn't matter if I had a full tank or almost empty it would drip which I couldn't see where because the metal shield protecting the plastic tank.
Old Mar 21, 2015 | 11:28 PM
hurst2001's Avatar
Is it leaking by the drivers side rear tire? If so it is your gas line .. They corrode in the frame rail.. Common place
Old Mar 22, 2015 | 12:22 AM
Some good tips in this thread - https://www.chevyhhr.net/forums/prob...ck-tire-49784/
Old Mar 22, 2015 | 01:29 PM
slanwar's Avatar
You probably right I just used my compressor to fill the tank with air and used my water hose around to see bubbles and nothing.
Old Mar 22, 2015 | 08:03 PM
Don06's Avatar
The fuel line leak is likely to be the next recall on these cars.
Goose
Feb 14, 2015 08:50 PM
Pancakes
Sep 19, 2014 12:34 PM
jason g
Fuel Economy - Hypermiling
Jul 17, 2013 09:16 PM
LittleChickenRacingTeam
Jan 5, 2008 09:47 PM
LSchicago
Nov 2, 2007 08:50 AM
