LED Upgrade
Old Aug 27, 2021 | 08:23 AM
Allen P's Avatar
LED Upgrade
Hey,
My right side headlight's connection terminal broke off,
so we're considering an upgrade to LEDs. I wanted to maintain the white color throughout so we're changing every yellow halogen on the outside.
These are the ones I've decided on :
H13 36W-36W
H11 (Fog Lights)
License Plate
Reverse Lights
Are 36W headlight bulbs okay?
Will they be bright enough?
And will I need anything other than just the bulb for the conversion?
Regards,
Allen P
Old Aug 27, 2021 | 08:56 AM
The fog lights aren’t H11 they are 9140 bulbs those headlamps are fine, the back up bulbs too provided they are 921
Old Aug 27, 2021 | 11:04 AM
Allen P's Avatar
Ok, can I use something other than 9140 - I couldn't find them.
Also, do I have to be worried about "flashes" or "flickers" because I'm not getting one of those conversion kits or resistors?
P. S I'm not changing the turn signal lights
Allen
Old Aug 27, 2021 | 11:32 AM
The fast flashing is in the turn signals.
I ordered H11 for my 2011 2LT they do not fit! The wire connector are different, and the mounting hole size is larger.
Google LED 9140 bulbs. I found a pair on Amazon.CA
Old Aug 27, 2021 | 04:21 PM
Allen P's Avatar
Aliexpress has me searching, and the fog lights are the only ones remaining.
These say H11 but are shaped like the 9140s
What du think?
NGN 1,908.41 61%OFF | H8 H9 H1 H3 Led H4 H7 H11 9005 HB3 9006 HB4 Car CSP LED Fog Headlight Bulbs 6000K White Auto Fog Lamp Day Running Light
Old Aug 27, 2021 | 04:46 PM
I know they are to large in diameter we’re they go into the fog light body and the 9140 wiring connector is different from the H11 connector.
Old Aug 27, 2021 | 08:07 PM
Lonwane's Avatar
I got my 9140's from Lasfit
Old Aug 28, 2021 | 07:39 AM
Allen P's Avatar
Will a H10 work?
Old Aug 28, 2021 | 08:19 AM
Lonwane's Avatar
If H10 = 9140, then yes they will.
Do your homework.
If not then you will have to return them or carry the loss.
Old Aug 28, 2021 | 10:43 AM
Allen P's Avatar
Do your homework.
That was easily said.
Thank you for the help
