Lift Gate won't open, amoung other things
Sounds to me like a wiring concern. In your owners manual there is a way of opening your tailgate manually, if you desperately need to. You will have to lower your rear seats and climb in. There are oval pop outs on the inside of the tailgate, the centre one is the one to remove.
Has your HHR been in any rear accidents?
Here's a "how to" thread on the emergency tailgate release that Tyler mentioned...
https://www.chevyhhr.net/forums/how-tutorial-library-21/how-manual-liftgate-release-8540/
If the fuses check out, then the dead brake lights and hatch do suggest wiring harness damage either accident related, or due to improper mods made for a hitch if equipped...or a custom audio system.
we can open it the 'manual' way no problem,, just not the proper way... it may have been in a accident,, small dent
Anyone know what the voltage should be on the brake pedal sensor? ours is at a 7
to the forum.
