Light problem?
Old Jul 25, 2016 | 04:29 PM
Originally Posted by Drifter.
Both Filaments were good on 2 diff. bulbs.
What wires do I jump exactly?
There are no trouble lights or codes showing up after a scan? This seems like a really dumbass thing, replace the cars computer to get a turn signal to work!!! What moron would design such a system......hopefully an unemployed one!!
I'm saying the computers DON'T fail!
When you get the switch out you can see what 2 wires get connected by the switch. Pretend that you are the switch and connect them.
I think it will be the yellow and black goes to the light and the black and white is hot. A VOM would tell for sure.
If you don't understand that, it is time to seek a pro.
Old Jul 25, 2016 | 05:30 PM
OK, my left turn signal does not flash, I have changed the bulb, the fuse is good, I checked power to the bulb, the running light has power, when the signal switch is turned on nothing. I checked voltage when switch was on no power going to the light.
What is between the bulb and the signal switch that could cause this? Are there other connectors I could check? Past experience with GM cars the signal switch is suspect when this happens??
If I could save the the 45 bucks the switch costs I would be a happy camper!
The wiring diagram in Haynes shows the underhood fuseblock(and of course the wiring harnesses) is between the bulb and the switch. If the switch is bad, wouldn't that cause the left rear turn signal to not work also? Does your left rear work?
Haynes also shows that left park/turn signal lamp shares ground with right front side marker lamp. And right park/turn signal lamp shares ground with left front side marker. Seems odd. Anyway, you could look at ground also.
Old Aug 5, 2016 | 01:43 PM
Drifter.'s Avatar
The turn signal saga is finished, not the bulb not the connector not the turn signal switch not the computer....it was a broken wire inside the wire bundle! Your guess is good as mine how that happened. All is good with the world again... today.. well my small piece of it anyway. Murphy does not sleep much! Thanks for the ideas!
Old Aug 5, 2016 | 03:30 PM
Could have been like in post #20? But hey you go it repaired!! That's the main thing!
urbexHHR
Nov 3, 2010 07:00 AM
06gray2ltHHR
2.4L Performance Tech
Aug 1, 2009 10:45 PM
ts5p
Oct 6, 2008 02:47 PM
Black Rose
Dec 7, 2007 11:28 AM
jimieno
Mar 17, 2006 06:14 PM
