Light problems
Old Jul 4, 2020 | 02:49 PM
Wesley Chatman's Avatar
Light problems
My daylight running lights, tail lights, and dash lights don’t work. I can ground the relay and everything works. I have change out the switch on the steer column no change
Old Jul 4, 2020 | 04:04 PM
Are you calling the corner marker lights "running lights".
Did they used to work? What happened to the care before they quit working.
The parking lights are on the same circuit as the marker lights. The should not be on in daylight.
Old Jul 4, 2020 | 05:35 PM
Welcome to the site, check the plug that connects the harness to the bulb, sometimes they get overheated and loose. And check the ground wires for the bulbs, could be corrosion
Old Jul 19, 2020 | 07:39 AM
the running lights yes I can jump the relay and the lights work. Yes they worked before
