Like I was out of gas...
Hello - I searched through all the gas tank / out of gas threads I could find but I am still a bit stumped.
Driving today my 2008 HHR LT died as I turned on to a side street, and would not run again. It would restart easily but would die, sputtering, less than 1 second later. Tried that about 5 times.
It really felt like I was out of gas - having experienced that before with another car.
I saw that the gauge said I still had 1/3 tank left, and just hoped the gauge was wrong.
Walked back home, and came back with a gas can. I dumped in 2.5 gallons and it started right up. "Great!" I thought. It wasn't anything more serious.
I drove to the next gas station and filled it up with 9.1 gallons.
Well the car holds 16 gallons, so 9.1 + 2.5= 11.6. So that means my gauge was not wrong, I really did have about 5 gallons in there earlier.
So what do you think might have happened?
Some crap sitting on the pump intake, and it got washed off when I dumped in the new gas?
I can't see it being a clogged filter because it would fail whether I had 5 gallons or 16 gallons in there, right?
Not sure what to do next but I feel like it's going to happen again and next time I might not be on a side street.
Thanks!!
Thanks!!
Thanks for your reply, OldBlue.
The pump sounds just like before, both earlier today and after getting more gas. When the key goes "on" I can hear it kick on for a moment. No change there in volume or tone of the pump.
I have an intermittent code for one of the O2 sensors (failing intermittently), but no current codes. (I have a reader).
I'll have a look at the fuse but I would assume that if I am hearing the pump turn on, whether I was "out of gas" or full, that the current is solid to the pump.
The exact code escapes me now Old Blue. I should have written it down but I have no short term memory anymore. It was one that indicated the O2 sensor (at the front of the engine I believe - the easier one to get to) was failing.
At the moment, the car is in the shop for a massive exhaust leak and I believe he will replace the fuel pump as well.
It has about 130k on the original so I wouldn't be surprised. I'll let you know hopefully later today.
