losing air in tires
Old Jan 25, 2014 | 04:14 PM
my first pannel's Avatar
my money is on that the tire guy didn't clean the rims with a wire wheel
Old Jan 29, 2014 | 02:18 PM
coolinc1981@att.net's Avatar
Greg
My 2010 with 40k miles is loosing air in all 4 tires. I've had to wire brush the
bead surfaces and use sealer on them. I'm trying to get GM to replace the aluminum wheels. This normally does not occur until 8 or more years pass.
Old Jan 29, 2014 | 05:25 PM
I'll bet there is a disclaimer for Aluminum wheels.
Old Jan 29, 2014 | 08:00 PM
redridehhr's Avatar
Aluminum wheels can corrode over time. Like previous reply, probably didn't clean bead surface.
Old Jan 29, 2014 | 08:12 PM
40 years ago we would not mount a tire on "mags" or aluminum wheels without tubes, on account of comebacks.
Old Jan 29, 2014 | 08:22 PM
Snoopy's Avatar
I don't believe you gave us a complete story. Did you just buy the car, has the tires been leaking since 2010, or have you had tires recently replaced? Basically, when did this problem first arise? A little more info would help us offer more valid suggestions/opinions. You also didn't state how much air you need to replace. Is it drastic or minimal?
Note: have an '06 with the aluminum wheels and have not had to add more than a pound or 2 every month or so....depending on our temperature.
Which brings to mind......you do know that tire pressures will change with the fluctuation of ambient temperatures. Generally 1 pound for every 10 degrees up or down.
Old Jan 30, 2014 | 12:45 PM
Rod Run's Avatar
In the amount of time you posted on here and had to keep checking back for answers, you could have gone to the installer and back already and had your problem fixed.
Just my 2 cents............
Old Jan 30, 2014 | 12:53 PM
Laco's Avatar
Originally Posted by Silverfox
Thats the Right answer but .....
Back in the good old day's we used to have a tire test tank full of water.
To check for leaks you get to put the complete assemby under water about a half at a time.
We would pump the tire up to Full Recommended pressure first.
We did not use soaps because in a tank it would be impossible to see a leak with all the suds created just by putting the assembly in the tank.
It was a sure fire method before all this high and mighty stuff we have now.
SF
Used that tank many times and it always showed where the leak was.
madashell
Nov 13, 2014 11:12 AM
zetrad
2.4L Performance Tech
Apr 18, 2010 12:22 PM
AJochum
May 30, 2009 05:51 PM
07Chevy
Oct 23, 2008 09:49 PM
