Lost my brake fluid
Old Apr 19, 2012 | 10:33 PM
geg's Avatar
geg
Sick front struts - the real source of the noise. Still need to check the attachment of struts. They get spoiled when the struts do not work.
The correct direction - the insulating material of the springs. x2
There are many more sources of noise (sleeve stabilizer, steering rack, weak attachment, etc.). It is easy to diagnose. And I like the words of emill713, he says the right things.
Old Apr 20, 2012 | 10:53 AM
Originally Posted by Major_Spittle
Good news so far. The dealer is getting parts to replace both rear bearings. They have fixed the brake line for a little over $200 ( I will have to talk to them about vibration from wheel bearing causing that issue and if they can cover that as related)
The said they will take it for a drive after replacing the rear bearings to see if the front bearings are bad. They also mentioned that one of my front struts is leaking oil.
Hopefully this stuff will fix the road noise as that is my biggest issue with the car now.
Thank you for sharing your update. I am glad that things seem to be going smoothly in getting this taken care of .
I hope you have a great weekend.
Old Apr 20, 2012 | 03:55 PM
RE: road noise. One more thing to check is the running board/lower skirt, the point of attachment is a really weak plastic piece right next to the jack points. Mine got broken, sounded just like a bad front bearing, my repair was shimming between the skirt and the fender, noise gone.
Old Apr 20, 2012 | 10:17 PM
emill713's Avatar
Thank you for the kind words geg. It is appreciated
glenngeb
Feb 4, 2019 03:56 PM
Rjj
Oct 22, 2017 08:56 AM
bad03xtreme
Maintenance and Upkeep
13
Dec 19, 2014 06:23 PM
hozer
12
Mar 16, 2014 07:06 AM
fastsuv
Feb 22, 2013 10:36 PM
