Manual SS tranny, no reverse!
Old Jan 13, 2010 | 07:31 AM
esmarkey's Avatar
I had something happen that has been bothering me...
Yesterday I went to park my manual SS, I went to put the car into reverse (after pulling up the reverse lockout) and the shifter easily went into the reverse position, with much less resistance than usual, but no reverse! I tried this several times, but each time with the same results. It was only after a few tries of going into 1st and then back into reverse it finally went in. When it finally went into reverse I could feel the extra (normal) resistance.
It seems to work okay for now, but should I be concerned and take it to the dealer, or is this something that can just happen once in a while??
Old Jan 13, 2010 | 10:09 AM
ZTony8's Avatar
You may have had some debris in the levers at the top of the transmission that fell out when you moved the cables by working the shift lever in the car.Monitor it and if happens again,take it in to your dealer.
Old Jan 13, 2010 | 10:42 AM
ChevyMgr's Avatar
Sounds like a cable problem to me also. Take it in if it happens again.
Old Jan 14, 2010 | 06:35 PM
esmarkey's Avatar
Well, not only did it happen again trying to get into reverse, but while driving in town it happened in 2nd gear.... Same thing, started in 1st, then went to shift into 2nd and very little resistance on the shifter, let the clutch out and nothing (neutral). Back into 1st for a moment and into 2nd. This time felt resistance and it went into gear.
She's got an appointment to go into the dealer Monday AM.
Old Jan 14, 2010 | 10:30 PM
MWG2's Avatar
Obviously it wasn't made in France because all they know is how to go is in reverse!! LOL.
Old Jan 18, 2010 | 09:37 AM
esmarkey's Avatar
Well, took it in this morning and they couldn't find anything wrong with it. There are no bullitens on the problem either...
At least it has been logged in the system.
Old Jan 18, 2010 | 09:57 AM
camaro98z28's Avatar
Mine does it as well sometimes. I shift into 1st and move just a tad and then I can put it into reverse. I think it gets caught between gears and doesn't allow the shift forks to go in reverse. I've also seen the same thing on my friends Ford Focus.
Old Jan 18, 2010 | 09:59 AM
Another thing I did was had the Shift Linkage adjusted because it wouldn't go into 3rd and 5th gear. Works like a charm since then
Old Jan 18, 2010 | 01:22 PM
esmarkey's Avatar
When it won't go into reverse, that's what I have found to work as well....
Gmando
22
Jan 16, 2022 05:56 PM
smalls10
Jun 3, 2009 02:48 PM
Tore
Apr 18, 2009 11:42 AM
kornellred
Oct 4, 2007 12:16 PM
nfboy
12
Jul 5, 2006 11:00 PM
