bumper fog light plugs
Old Jan 13, 2010 | 06:52 AM
Skatetheglobe's Avatar
Anybody have any tips on how to get the plugs out of the fog lights holes on the bumper?
Old Jan 13, 2010 | 07:01 AM
solman98's Avatar
They snap in from the rear.
Old Jan 13, 2010 | 07:04 AM
I pulled the shroud from the wheel well but I can't get them to budge. It there a method like squeeze and twist? I can only get one hand in there without completely removing the shroud.
Old Jan 13, 2010 | 07:34 AM
solman98's Avatar
There a a couple of release tabs to unlock it. I can't remember exactly how many. But they do come out. Just release and push in from the outside.
Old Jan 15, 2010 | 01:11 AM
NxlKing2304's Avatar
to be honest, you are probably better off taking the whole bumper fascia off the car to take the fog light inserts out, this way you can see all of the hold points. I blieve there are 3-4 points in which it clicks in place. Place a Flat-head screwdriver and wedge each one untiil they all POP.
Of you can do what I did with mine, since I was putting in fog lights anyway, I just cut the tabs off and they popped out very easily. Parts went from bumper to trash very quickly.
Old Jan 15, 2010 | 05:51 AM
solman98's Avatar
MIne were not hard at all to get out. I just felt around the plug until I found each tab, released while pushing in a little on the outside. Took maybe 5 minutes to do each. That includes removing the screws in the wheel well.
Old Jan 15, 2010 | 03:02 PM
I finally got them out. Thanks for the tips guys.
Old Jan 18, 2010 | 06:22 PM
Stan M's Avatar
Is there any wiring already run to the fog light locations? I have heard rumors that the wiring harnesses in many newer vehicles have the connections for all possible accessories, and that you need only add the accessory and the switch. That sounds too good to be true.
Old Jan 18, 2010 | 06:50 PM
Sno White's Avatar
If it sounds too good, it is.
There are several threads discussing having to add a switch and wires for fog lights.
Old Jan 19, 2010 | 09:24 AM
Stan M's Avatar
I saw those threads afterwards. Apologies for the redundancy.
Twistedtat
"How To" Tutorial Library
Nov 2, 2014 12:19 PM
goseecal
Drivetrain (Excluding Engine)
Oct 29, 2014 12:07 PM
Gas Man
May 7, 2012 04:44 PM
gangster moblie
Maintenance and Upkeep
42
Sep 5, 2011 05:54 PM
craigs300
Apr 4, 2011 11:50 PM
