Manual Trans Fluid
Old Oct 15, 2018 | 11:57 AM
fastsuv's Avatar
Manual Trans Fluid
I am going to replace a driveshaft on my 2006 HHR 1LT 2.4L with the manual trans.
I know that some fluid will come out when I pull the shaft out of the trans.
I'm at work now and don't have my service manual here. I need to get the fluid on the way home so I can do the repair tonight.
Searching the forum shows some posts from 2015 saying to use only the GM stuff.
What the latest on fluid for the manual trans? Mobil1 ATF? Napa brands?
Thanks
Steve
Old Oct 15, 2018 | 12:13 PM
You shouldn't lose much. The recommendation is Dexron VI don't care about brand. See your Owner Manual. May have come from the factory with Dexron iii. Yes ATF in a standard.
bad03xtreme
Maintenance and Upkeep
13
Dec 19, 2014 06:23 PM
gamma-wes
May 17, 2014 10:13 PM
c2vette
Feb 10, 2009 08:14 AM
Wodinator
2.2L Performance Tech
Nov 14, 2007 03:36 PM
BelizeBrian
Jan 23, 2007 11:28 PM
