Manual transmission issue
Old Jul 3, 2021 | 06:28 PM
Mchristensen808's Avatar
I have a 2006 manual transmission. Today when i went to shift into first the car made a grinding sound so i immediately released the clutch and put it in neutral. When i attempted to shift into first again there was no resistance on the shifter lever. Then i notice the shifter moves freely without pushing in the clutch pedal. Where should i start looking to repair this issue? I was thinking the transmission linkage could be the possible culprit. Are there any videos that might help?
Old Jul 3, 2021 | 06:43 PM
The shifter is cable controlled . Lift the console cover and check to see if the cable broke or popped out of the bracket
https://parts.islandgm.com/p/Chevrol.../15277760.html
Old Jul 3, 2021 | 07:26 PM
The cables are still connected. I can see the end underneath the hood by the transmission and they move when the shifter is moved. When the shifter is in the first gear position, i can push it to the left with no resistance as if it was in neutral. Is my transmission toast?
Old Jul 4, 2021 | 06:51 AM
In the words of the great Bugs Bunny…. Ah, could be!!
something broken inside the gear box.
NikiJ37
Sep 8, 2016 11:15 AM
gbell73
Apr 3, 2015 12:49 PM
RedTurboSS
Dec 19, 2013 08:48 AM
berky1976
Jun 26, 2012 02:22 PM
coolzzy
Oct 10, 2011 10:24 PM
