Help.2007 HHR LT ....shifter is very sloppy and will not go into any gears
): I was driving my 2007 Hhr Manual 5 speed all of a sudden the gears went sloppy....any ideas of what happened. It will not go into any gears.......cranks up fine and the clutch is strong ....just the gear shifter is very sloppy!!!!!😞
Sounds like a broken or disconnected shift cable issue.
Here is a link that might help show what it all looks like under the console with the cable arrangement (it's a different car, but it is pretty similar) - http://www.twmperformance.com/manual...n%20Manual.pdf
ImNewHere
Jul 31, 2014 07:22 PM
Bushmaster11B
Drivetrain (Excluding Engine)
Oct 18, 2012 05:58 PM
Kates 2006 HHR
Aug 31, 2009 02:39 PM
