Mountain Dew spilled down in shifter now it takes a while to shift into drive
Old Aug 29, 2009 | 08:54 AM
Kates 2006 HHR's Avatar
I was trying to see if any of you have a diagram of the 2006 HHR floor gear shifter. My daughter spilled a Mountain Dew down in it and now it does not like to shift out of park. It may take one try and it may take 20. Any help I can get that would be great.
Old Aug 29, 2009 | 09:10 AM
ChevyMgr's Avatar
Preliminary Procedures
•Remove the front floor console. Refer to Front Floor Console Replacement
•Disconnect the shift cable from the shift control. Refer to Floor Shift Control Cable Replacement .
1 Instrument Panel Center Support Bracket
Refer to Instrument Panel Center Support Bracket Replacement .
Tip
Disconnect the shift lock solenoid electrical connector.
2 Shift Control Nut (Qty: 4)
Tighten
10 N·m (89 lb in)
3 Shift Control Bolt (Qty: 4)
4 Shift Control
Old Aug 29, 2009 | 10:12 AM
Thanks for the information
I will let you know if it works.
Old Aug 30, 2009 | 07:25 PM
DANNY HUNTER's Avatar
Wd-40 works wonders and you wont have to take it apart
Old Aug 31, 2009 | 05:28 AM
Jeff®'s Avatar
WD-40 won't dissolve sugar. Use distilled water, and lots of it. Then after it dries, spray the lube.
Old Aug 31, 2009 | 02:39 PM
Smile Mountain Dew in Floor Gift Shift Assembly
We took the gear shift assembly out and cleaned it and so far so good. Thanks again for the diagram. I am sure you saved us alot of money showing us how to do it ourselves.
sklute
May 17, 2015 02:27 PM
crazysteve
"How To" Tutorial Library
24
Jun 21, 2009 07:15 PM
mnmarlin
May 13, 2008 04:20 PM
