heated seat light
Is it really cold enough in Michigan already to be using the seat heaters???
I've seen this before in my HHR but it only happened a couple times after the seat heater had been on for a long time. I assumed it was blinking and shut off as a result of exceeding some sort of temperature. After it shut off I hit the button again to turn it back on and everything was fine again.
If you have this problem often and are covered by warranty get it checked out.
