Mechanic said my 2009 HHR 2.4L engine “is toast”
Old Jun 27, 2025 | 07:52 PM
GT55's Avatar
Update: just drove it home from the mechanic’s shop. Sounded good, ran smooth. Wife following behind noticed smoke from my tailpipe. Neighbor came over & we checked the oil. He said it was still good & full.
Old Jun 28, 2025 | 08:57 AM
Don’t panic about the smoke, but ask her what colour was that smoke? White or blue?
Old Jun 28, 2025 | 09:59 AM
Can you get a photo of the harmonic balancer ?
It’s behind the plastic inner fender Look for oil in that area
Old Jun 28, 2025 | 12:26 PM
GT55's Avatar
Wife is at work & just replied—smoke was whitish-gray
Old Jun 28, 2025 | 02:50 PM
So coolant or water…. Could be a head gasket problem
Old Jun 28, 2025 | 03:14 PM
  #26
GT55's Avatar
Ok, in what sense? Thanks for all the info and replies!
Old Jun 28, 2025 | 04:03 PM
  #27
In the sense the head gasket might be allowing coolant or water past it to the combustion chambers or out to the outside of the engine
A compression will verify that.
Old Jun 28, 2025 | 04:19 PM
  #28
GT55's Avatar
Ok thanks. I mentioned a compression test to my mechanic and he dismissed that outright. So I found another mechanic who will do it.
Old Jun 29, 2025 | 07:15 AM
  #29
Good, hopefully the new guy is an honest man!
Old Jul 3, 2025 | 02:29 PM
  #30
GT55's Avatar
Ok new mechanic says cylinder 2 ignition is weak. Crankcase seal is leaking AGAIN, despite previous mechanic claiming he fixed it.
New guy is gonna do a hydrocarbon test before going further. He said a new head gasket replacement would be extremely expensive. Ugh.
Everything he checked & noted is at this link below. Would love to know what you guys think.
https://smky.app/n3jp5r
