Mechanic said my 2009 HHR 2.4L engine “is toast”
Old Jun 27, 2025 | 01:01 PM
greg8453's Avatar
When an oil light starts flickering your engine is very low on oil. You should stop immediately and check it. If something blew and was causing heavy loss of oil you may not get another 5 miles and throw a rod or seize up
Old Jun 27, 2025 | 01:05 PM
GT55's Avatar
I guess I knew that, but I had to get to my medical appointment.
Old Jun 27, 2025 | 01:20 PM
Ok check the oil and top up before you head to your new mechanic appointment, let him find the oil leak point and access the problem, don’t discuss the last guy’s findings, well because he didn’t find the leak!!
Old Jun 27, 2025 | 03:58 PM
PulpFriction's Avatar
From what I've read.I don't trust your mechanic(s) and neither should you. Replacing the (pan gasket?) and then having it leak all the oil out makes no more sense than an oil leak causing multiple belt launches even after a mechanics machinations.
Sure, it's a lot easier to put in a new engine than to actually figure out what's wrong with the old one first. However, if it ran for even a short time with oil light on, it is indeed possible the the engine is "toast."
Old Jun 27, 2025 | 04:30 PM
GT55's Avatar
Yeah I don’t understand how he said he saw a leaking crankcase gasket, then he replaced it and fixed it, but 4 days later it’s leaking oil again when I had to get to my medical treatment. He and his kid both said when he started it up with the oil cap off, it felt like a leaf blower.
So, should I even bother with a compression test at another mechanic?
Old Jun 27, 2025 | 05:09 PM
The car isn’t worth $8000 of repairs. Probably not even worth half of that after the repair.
You’d be wiser to spend the repair money on a nice used car.
And what is this so called crankcase gasket ? I think you may have your terms mixed up.
Did he say Timing cover ? Oil pan ?
Old Jun 27, 2025 | 05:23 PM
GT55's Avatar
Oil pan gasket, I assume. Got any recs for a good used car?
Old Jun 27, 2025 | 05:26 PM
GT55's Avatar
Or the front crankshaft seal, behind the harmonic balancer, maybe?
Old Jun 27, 2025 | 07:11 PM
Most likely this.
Did he fill the oil each time he serviced it(Serpentine Belt, alternator, etc)?
Old Jun 27, 2025 | 07:21 PM
GT55's Avatar
Yes. He constantly harped on my vehicle being low on oil.
