Misfire Mayhem
Old Jun 11, 2023 | 07:27 PM
PBwithJ's Avatar
yeah sorry..... it was a 0017 code.... misfire cyl #1
i swapped injectors around and that was it so new injectors runs great!!!
then I had the crank cam code again, turns out i was off on installing the exh. cam sprocket, re-did that and got a too rich code did a throttle relearn, now ZERO CODES but...
when it sits not running for more than a minute or two, upon starting, I have to crank it longer 5-6-7 rotations... it NEVER did this until now, always started on the first turn... weird.
so now that's the only thing left to solve, bestow your knowledge upon me!
Old Jun 11, 2023 | 08:03 PM
EVAP purge valve.
Or fuel pump.
Old Jun 11, 2023 | 08:13 PM
You shouldn't hold the key in the start position. Just turn it to start and then release the key. It will crank until it starts or times out.
Old Jun 11, 2023 | 08:15 PM
PulpFriction's Avatar
P0017 was the code that was telling you and everyone else that the exhaust cam sprocket was mistimed.
You only need to turn the key momentarily. Doing so initiates the start sequence and it will crank until it starts... or doesn't. What injectors did you use? Any smoke or sputtering at startup? You could monitor the a/f once the car warms a bit with a scan tool to see what's going on. Look at short and long term trim. The long start could clear up after a few run cycles.
What spark plugs are in it, brand and exact p/n? Keep checking for codes, even if no CEL.
Old Jun 12, 2023 | 08:27 PM
PBwithJ's Avatar
Ok so now hard to start after sitting 5 minutes,
fuel pressure test: key on 55lbs, running 55-60lbs doesn’t dip under throttle, key off pressure decreases slowly to zero in about 5 minutes, leaky injectors? They are new but china/Amazon ….
Old Jun 12, 2023 | 08:28 PM
PBwithJ's Avatar
On startup slight sputter then runs fine , no smoke
Old Jun 12, 2023 | 08:35 PM
PBwithJ's Avatar
Originally Posted by donbrew
EVAP purge valve.
Or fuel pump.
today YouTube certified mechanic videos told me I should be able to blow through the evap solenoid, well I can’t blew blow through the new one either but it has a new one. It was cheap, but not China cheap. I got it at O’Reilly’s.
Old Jun 12, 2023 | 08:42 PM
greg8453's Avatar
Your certified mechanic lied to you. They are normally closed.
Old Jun 12, 2023 | 08:47 PM
greg8453's Avatar
Does it start hard and smell of gas after sitting for 5 minutes? If not, then the fuel is leaking back into the tank through a bad valve in the pump.
Old Jun 12, 2023 | 08:57 PM
P0017 is not defined as misfire, it is defined as timing chain problem. Whoever you are getting info from is a dummy.
P0301 would be misfire cylinder 1.
Test the fuel pump. After it turns off watch the gauge for 10 minutes looking for the pressure to drop if it goes to 0 in less than 10 minutes you need a new pump. There is supposed to be a check valve that keeps the rail primed.
