Misfire Mayhem
Old Jun 27, 2023 | 11:26 PM
  #71
PBwithJ's Avatar
starting video hard start .
on 1st try it stops cranking before i release the key,
2nd time just cranks too long stumbles to a start.
slight little dieseling when shut off.
then will fire up at the bump of the key.
it's exactly the same every time.
Old Jun 28, 2023 | 09:11 AM
  #72
Sounds like fuel supply.
Does the pressure hold for 5 minutes after shut off? Maybe, hook the pressure tester up then watch it while trying to start.
If you open the Schrader valve with engine off gas should spray out, even after hours of sitting. Cover with a rag to prevent gas in your face.
Maybe, junk in the fuel rail.
Try turn the key to run for 2 seconds then off, a couple of times before trying to start.
I can't tell from the vid, you should be releasing the key immediately, it is a momentary switch. Then off (not run) before the next try. The fuel pump only runs for 2 seconds without a start, after 2 seconds of cranking you are wasting battery.
"Exactly the same", even if you shut down then try again right away?
Are the spark plugs ACDelco 41-103?
Old Jun 28, 2023 | 10:27 AM
  #73
greg8453's Avatar
Ignition switch?
Old Jun 28, 2023 | 10:32 PM
  #74
PBwithJ's Avatar
SOLD IT AS-IS GOOD RIDENCE...... but thank you all for trying your best to help
Old Jun 29, 2023 | 08:08 AM
  #75
PulpFriction's Avatar
You're welcome. Still wondering what injectors are in it. (Maybe I missed it.) Dieseling suggests a leak; no more fuel should be released after shutdown. I know, all academic now. Just curious. Or maybe we'll hear from the new owner.
tiger Joe
Jul 25, 2023 02:29 PM
Frisco84
Apr 23, 2022 05:43 AM
uluz2a6
May 25, 2018 06:17 PM
Muddie
2.2L Performance Tech
18
Nov 25, 2016 06:23 PM
bhamsoxfan
Nov 22, 2013 11:51 AM
