Mount up! We’re tracking shimmy shakes! An engine transmission mount problem
Old Sep 6, 2019 | 10:41 PM
Tokin. Check your part numbers again. You've got a mix of auto and 5 speed mounts.
Here's a list for the 2008 model since you didn't give a year. #6 is a mount bracket. #7 a heat shield( their listing got cut off my screen capture)
Old Sep 7, 2019 | 08:29 AM
From RockAuto site for 4spd automatics
The 5spd manual transmission mount
Old Sep 7, 2019 | 02:17 PM
Tokin's Avatar
Ugh, why doesnt this come up in my searches? Thank you!
I bought new reader glasses today, maybe they will help, good grief.
Old Sep 7, 2019 | 11:31 PM
You might look here https://www.chevyhhr.net/forums/comm...rt-numbers-68/ the first sticky is a nice pdf catalog.
Old Aug 16, 2021 | 10:40 AM
desertrat's Avatar
I replaced the front mount about 2 weeks ago, it was original with 163,000 miles. It looked good, but by replacing it an annoying rattle at idle disappeared along with some front end noise. Looks were deceiving, there was some minor cracks but it was worn out. It cost $100 and was easy to replace.
Old Aug 20, 2022 | 12:55 PM
BillieBrew's Avatar
Forth Mount location
Does anyone have a good picture or diagram of the forth Mount location? I have changed the other three, but can’t find the forth. Thanks
Last edited by RJ_RS_SS_350; Aug 20, 2022 at 01:03 PM. Reason: Removed very long quote
Old Aug 20, 2022 | 01:14 PM
Hi BillieBrew, to the forums!
Here's the diagram for automatic transmission, you're looking for #1? Possibly only visible with the fuse block removed.
Old Aug 20, 2022 | 01:42 PM
BillieBrew's Avatar
Thanks
They did a great job of hiding it ! 😂
Thanks again for the help
Old Aug 20, 2022 | 02:24 PM
BillieBrew's Avatar
Torque specs
Hey , do you know torque specs for #1?
thanks again
Old Aug 20, 2022 | 02:48 PM
GM is calling it the side mount. According to the Haynes manual, mount-to-frame bolts are 25 lbs ft, and mount-to-transaxle bolts are 48 lbs ft.
That doesn't agree with the specs we have in our torque spec thread here https://www.chevyhhr.net/forums/how-...e-items-54648/
