Need electrical help
And then the new/swapped relay burns out because it turned out to be a circuit problem.
But yes, that is what a flat rate mechanic would do; much more money in swapping parts instead of doing the work they are getting paid to do, an hour of diagnostic time for 4 minutes work. Then if it turns out to not be the relay charge the customer for the parts because "electrical parts are non-returnable". Been there, done that; a Ford dealer replaced all of the emissions sensors because they were listed as "possible causes", couldn't be bothered to do testing. Stated symptoms "CEL on, heater blowing cold air, running rough"; it was a stuck open t-stat, ambient temperature 15F.
