Need help! 2009 HHR!
Old Oct 23, 2013 | 12:28 PM
shootingstar85's Avatar
Originally Posted by shootingstar85
I've had it for almost 2 years. This is the first time I've had any problems with it.
Today car is running great! Check engine light is still on but it hasn't been reset. Drives with no miss, idling smoothly with no service ESC/ traction.... Kinda weird, it has days it runs good and days it misses bad and wants to stall out...
Old Oct 23, 2013 | 07:46 PM
If you want to turn off the ECL, you can disconnect the NEGATIVE battery post under the trunk's floor, (next to the spare tire) for 5 mins, then reconnect it. You just have to be careful not to short out the negative side of the battery to the positive side.
That is sorta good news, that it is running well, but whatever is causing the problem hasn't gone away. The computer is constantly analyzing things, and if it detects certain errors over a period of time/and or distance, it will light up that CEL.
Oh, check the invoice/workorder from the mechanic that changed the plugs - these cars get real fussy if using anything other than Delco Iridium plugs sparkplugs, and can generate misfires as well.
gib68chevy
Jun 27, 2013 01:13 PM
masterbob
Apr 13, 2010 11:23 PM
GDZHHR
Dec 7, 2008 05:23 PM
