Need PN/links to purchase 2.2 auto TPS pigtail harness
Old Oct 20, 2015 | 06:06 PM
nrodwal's Avatar
Can't seem to find this bugger anywhere - found some on eBay but I bought one and it wasn't even close to being made of the same thing (thicker, silver wiring instead of copper like wtf?)
Assistance would be appreciated.
Old Oct 20, 2015 | 10:29 PM
You mean like this AC Delco PT 2713
ACDelco PT2713 GM Original Equipment Black Multi-Purpose Pigtail, Throttle Position - Amazon Canada ACDelco PT2713 GM Original Equipment Black Multi-Purpose Pigtail, Throttle Position - Amazon Canada
Or this Standard Motor Products S1745
Standard Motor Products S1745 Connector | eBay
Which one did you get?
Old Oct 21, 2015 | 01:05 AM
nrodwal's Avatar
This piece of junk:
Throttle Actuator Connector ACDelco GM Original Equipment PT2713
http://www.ebay.com/itm/281563592157?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Oct 21, 2015 | 08:10 AM
quite the price difference, may I suggest you contact the seller and arrange a return and a refund.
That being said, stop by your local parts palace like AutoZone or Advanced or O'Reilly's
Ask to see these parts to ensure they are up to your standards before you buy one.
Old Oct 21, 2015 | 08:42 AM
X2, buying parts on e-bay can save some bucks, but there's a ton of crap out there too.
Unfortunately, you got the short end of the stick nrodwal.
Old Oct 21, 2015 | 03:24 PM
nrodwal's Avatar
That I did. Moving on though, I suppose Oldblue's link for the S1745 part is the one I need, rather than the PT2713?
Old Oct 21, 2015 | 06:58 PM
Check that Standard part at your local parts palace like AZ AAP O' R! Have a look before you buy
Old Oct 31, 2015 | 11:33 PM
nrodwal's Avatar
It appears that I'm having problems with voltage input/output and the engine is now disabled, according to the gauge cluster. Disconnecting battery and unplugging the ECM/BCM/TCM didn't help either.
Old Nov 1, 2015 | 05:36 AM
Dbeluscak's Avatar
I'm wondering what lead you to change the TPS harness out. Was it visually damaged?
What did you mean by the engine is disabled?
Since you said according to your DIC, I would assume it reads "ENG PWR REDUCED" which is no fun for anyone.
Reduced voltage is definitely sign of bad wiring, but it could be loose/bad connections in the throttle body. I've got a spare harness and I can pull the TB off my 2.2 and we can ohm it out together.
  • Taking off the TB literally takes a minute. A flathead screwdriver and a 10mm socket with extension is all that's required. Pop off the air box, four bolts hold it in place. And the gasket is reusable. Way easier than the SS!
Old Nov 1, 2015 | 07:16 AM
nrodwal's Avatar
Well, all 3 harnesses LOOKED somewhat dirty, thought it would be a good idea to clean them up with WD-40 (well not my idea - old man).
That's right, "ENG PWR REDUCED", followed by "ENGINE DISABLED".
I will get you those ohm readings later this afternoon!
