New Battery Installed Lost Radio and Sounds
Folks, I just found this old thread. My SS seems to be having this exact issue. I disconnected the battery for something completely unrelated to the radio. After reconnecting, the radio is completely dead. Fuse #23 seems fine. Was there any final resolution to the situation in this thread?
Correct. I have no audio. I have no display on the radio. I push its center button to power on and get nothing. The car starts and drives fine. But the radio is completely lifeless. And today's battery disconnect was not intended to affect the radio at all.
I had that issue, there’s a few companies that will revive your head unit , some internal circuits need to be repaired. Or just get a replacement radio from where ever you like. Crutchfield has the adapters and brackets.
I'm really perplexed as to what could have damaged the radio. This is not the first time I have disconnected the battery in this car and the radio has been fine each time. Do you know the names of any of those companies?
If yes, then your next step should be to pull the radio and check for power to it at the plug in. No sense in buying a new radio if there’s no power at the harness.
@Oldblue by chance, did your repair friend tell you what diode was toasted? I'm wondering if I can take it to an electronics guy with that information and have them replace that diode to get it working again.
