New Battery Installed Lost Radio and Sounds
Old Aug 10, 2019 | 05:40 PM
  #31
Can you put in the radio from the black Swan, as a test, see if you at least get turn signal clicks back?
Old Aug 10, 2019 | 09:43 PM
  #32
Great theory RJ , but then there’s the possibility of damage to that radio , or if I put the radio out of Oldblue into the Black Swan.
I think one good working radio is much better then two fried ones.
I spoke to my new neighbor, he’s a computer design guy retired from IBM , I gave the dead radio to him to disassemble it and test it , he believes he can repair it .
Old Sep 1, 2019 | 10:32 AM
  #33
Canaan's Avatar
Ok, I'm having the same issue. The radios completely black and no clicking for the turn signal, though they still turn on, and I just replaced my battery yesterday.
Old Sep 1, 2019 | 11:48 AM
  #34
Did you do anything else?
Check the maxi fuse near the battery.
Old Sep 1, 2019 | 12:47 PM
  #35
From what I’ve gathered , the diode in the radio is toasted. There is a member here who had a link to a repair shop
Old Sep 10, 2019 | 10:24 AM
  #36
vogtrj's Avatar
This has me wondering...
Since it seems like the battery change is zapping the diode in the stock radio, would it be advisable to remove inside fuse #23 when changing/reconnecting the battery?
Old Sep 10, 2019 | 11:12 AM
  #37
I just replaced the radio, I don’t want to test that possibility.
I think the radio still gets power thru the BCM.
Old Sep 10, 2019 | 12:32 PM
  #38
It gets constant power from the fuse (clock etc); it gets the on signal from the BCM.
Old Sep 11, 2019 | 07:44 AM
  #39
From the BCM thru the radio on signal wire, I’ll stop there because, I don’t have evidence to confirm the source of the voltage spike or short circuit
Old Sep 11, 2019 | 08:24 AM
  #40
The "on/off" signal comes from the BCM on the GMLAN. That's why you need an adapter or a switched source.
