New ECM troubles...
Old Jul 15, 2016 | 06:08 PM
thehappyfrog's Avatar
Harness seems good, the TB adapter is what they sent us. So one thing down Great to have someone to work with ideas on, thanks again.
Old Jul 15, 2016 | 06:51 PM
The electronics in the TB are a bit complicated. That could be it, shorting something.
I could get the connector pinouts if needed. But, note the colors and pins are different here.
This is for 2007 HHR 2.4L.___________________________ This is a 2007 Cobalt SS
Old Jul 15, 2016 | 06:59 PM
LSJ TB is the new one. Great schematic! We got the 8 pin adapter from 2.4 TB to new LSJ TB.
Old Jul 15, 2016 | 07:09 PM
I was adding stuff as you were typing.
Old Jul 15, 2016 | 07:50 PM
So your car is a 2007 2.4L and the TB is from a 2008 Cobalt SS 2.0L?
There were differences in years in both HHR and Cobalt. Need to know specifics.
Old Jul 15, 2016 | 09:06 PM
Excellent point, this is making a lot of sense. LSJ TB is from "Cobalt SS LSJ Supercharger kit 2004 to 2007 Ecotec Redline 2.0 2.2 2.4" compatibility. I can go tomorrow to get a part or serial number if needed.
Old Jul 15, 2016 | 09:49 PM
I've been looking around a bit. Seems 2007 HHR 2.4L is the same 8 pin connector as a 2007 Cobalt SS 2.0L. The 2.2L HHR is 6 pin.
There wasn't a Cobalt in 2004, Who would want to SC a Cavalier?
pinouts
Cobalt on top HHR on bottom
Old Jul 18, 2016 | 05:41 PM
That's helpful. I've seen people to do weird things to cavaliers lol So we removed the IC pump wire completely just to be sure it's not shorting something, replaced the ecm and tcm with another stock and flashed just to eliminate that, and still nothing. I'll try another throttle body.
I do have an LSJ throttle body which is different wiring from the stock 2.4lt. ZZP sent an LE5 TB to LSJ TB 8 pin adapter so it seems that's good.
If it's not the TB being bad I'm out of ideas.
Old Jul 18, 2016 | 06:07 PM
The adapter. That's why I went to the trouble of posting the pin assignments. You might look at the wires and make sure they go to the correct pins on the TB.
The connectors are the same, the pinouts are different.
Old Jul 18, 2016 | 06:45 PM
I wan't using my brain apparently, of course I know what you mean now. I'll check the adapter pins tomorrow to make sure. Again, thanks for the help I appreciate it!
