New wheel bearing noise
Hello all, I wanted to run this by everyone to see what some of the thoughts were.
I have a 2008 LT Panel. 2.4 automatic. 4 wheel ABS. 88k miles. I have owned the car for 14k miles. I Have replaced all front suspension components since I've owned it. Also had new dealer installed front axles. Recent new tires. I Recently replaced front bearing hubs and tie rod ends myself, then had an alignment. Now, for whatever reason I have a bearing humming sound that appears specifically at 35 mph...
I have no clue other than maybe I didn't get the axle nut tight enough, but I hit it a bump past 155 ft lbs. and was afraid to go anymore than that even though I hear a click not when I put it in reverse. OR, i have a crappy "new" bearing. Anyway, hoping all of this is somehow relative to the humming noise at 35mph. Thanks
Branden
I have no clue other than maybe I didn't get the axle nut tight enough, but I hit it a bump past 155 ft lbs. and was afraid to go anymore than that even though I hear a click not when I put it in reverse. OR, i have a crappy "new" bearing. Anyway, hoping all of this is somehow relative to the humming noise at 35mph. ThanksBranden
Yeah thats what I was afraid of. Just wondered if there might be something else going that you all knew about. it's almost like a harmonic type of noise. Anyway. Just wondered why you thought I need a new nut, old blue? Also, yes Donbrew, I know that it has rear bearnings and that they also need replaced as well. Just curious what my other options might be for the rear wheels other than bearings? Maybe I missed something. Thanks
Update: I ended up getting 4 new MOOG hub assemblies from Rockauto.com. I got the front hubs replaced yesterday with new Axle nuts, torqued to 155, and it did not fix this funky humming sound that I have. Whats best is, when I got them installed and drove the car around for a bit it seemed as though it was fixed. I didn't really hear it, but when I took off this morning it was back but not as loud as it was with the other hubs that I put in the first time. I will put the rear hubs on later today although I don't think they are causing this noise. It is coming from the front. I have read other posts about humming noises but they have all been bad hubs in the end. Now I'm wondering if it is something in the transmission or something that I didn't think of. Just wondered if anyone else has had this problem that was not hub related? The noise does not change with turning or speed changes. It is just there, this harmonic sounding hum.... around 35mph hmmmmmmmm........Thanks
Have you revved the engine up while parked, to test for flex pipe?
Could be a bad CV axle.
Could be bad alternator
Could be a bad serpentine tensioner.
Could be a bad A/C.
Could be tires. Are yours "directional" or "this side out".
Could be a bad A/C.
Is it only around 35mph, OR speed changes don't effect it.
