No coolant temp reading and the thermostat was changed
Old Oct 20, 2017 | 07:24 PM
Could be the sensor or it's wiring.
Old Oct 20, 2017 | 07:30 PM
mrmarkuSS's Avatar
Originally Posted by Oldblue
It’s been mentioned many times here, the aftermarket t-stats do not open in the time frame the computer is calibrated for , the the code gets thrown. Most likely P0128.
And only use Dexcool 50/50 mix, these Ecotec engines were engineered for it.
I never saw that at all about the T-stats,just the simple "replace them".
NOW that I have the paperwork firemangeorge,I can confirm Oldblue nailed it. Paperwork shows a P128 code.
And as far as the Dexcool,what I drained in a pan I put back in and only needed to add almost a pint of water when I finished.
So,looks like I'm doing this all over again...
Old Oct 20, 2017 | 08:47 PM
The search engine here isn't the best. The default 'Threads' sorts by the date/time stamp of the most recent post in a thread that has the search criteria in it somewhere. If you change to 'all' you get a search powered by google, sorted by relevance, which usually gives you better results.
That being said, the newer the advice, the more accurate it should be. The older posts are often closer to guesses, as there wasn't as much hard facts yet on a new HHR.
Old Oct 20, 2017 | 09:11 PM
mrmarkuSS's Avatar
That's how I start off,with Google and click on the ones from the forum...
Since I know what I'm in for with the thermostat R/R,the second time around should be a breeze...
JGiaccio
Jun 8, 2016 09:35 AM
GibsonHHR
Jun 11, 2015 06:41 PM
oldracer
Maintenance and Upkeep
Jul 4, 2014 10:53 PM
Leemor
Jun 9, 2014 06:33 AM
TechnaDriver
Mar 23, 2014 05:21 PM
