No Electric Power - New battery
Old Jun 7, 2025 | 12:53 PM
johnk's Avatar
Nothing works, no lights, no radio, no windows, no starter - nothing. I have installed a new battery (both old and new check at over 12 volts). Voltmeter reads over 12 volts at the terminal on the rear side of the underhood fuse box and 0 at the terminal at the front side. Would seem to me that there is some kind of break in current in the fuse box??? Any suggestions?
Old Jun 7, 2025 | 12:56 PM
greg8453's Avatar
How about a little history.
Old Jun 7, 2025 | 01:26 PM
The rear terminal close to the firewall in the centre of the car should have a single wire, that’s the electric power steering 12 volt terminal. The forward terminal, under the red cover should have 2 wires , from the battery is one and on to the starter is the other. I suggest you inspect the fuse back by the battery.
Old Jun 7, 2025 | 01:50 PM
The fuse by the battery is power to the BCM.
Maybe somebody hooked the wires up backwards. Did this start after a engine/transmission/fuse box replacement?
Old Jun 7, 2025 | 02:07 PM
johnk's Avatar
Car sat for about 15 months - though started about once a month. Started driving about 6 weeks ago. No problems. Then on a 90 degree day, I killed the engine when starting from a stop. All went dead. As above, nothing electrical seems to work. Has 180000 miles.
Old Jun 7, 2025 | 02:10 PM
johnk's Avatar
Here's a pic. Two wires at firewall, one at radiator ends.
Old Jun 7, 2025 | 02:12 PM
johnk's Avatar
No changes have been made in last several thousand miles.
Old Jun 7, 2025 | 02:14 PM
johnk's Avatar
Where is a fuse by the battery? If it were blown how would power get to the fuse box? I am not an electrical guy, obviously!
Old Jun 7, 2025 | 02:22 PM
johnk's Avatar
Old Jun 7, 2025 | 02:24 PM
johnk's Avatar
