No power.
Old Feb 25, 2017 | 02:53 PM
Rob Sayan's Avatar
No power.
2007 hhr no power no brake lights no horn. no blown fuses. cant shift. did replace battery. help i am stuck
Old Feb 25, 2017 | 03:09 PM
Welcome to the site, check your under hood fuse box, they've been know to come loose!
Switch a matching relay to the starter relay, they been found to be burnt at the contact s
Old Feb 25, 2017 | 03:48 PM
Hi Rob, to the forums!!
How about a little recent history, what happened right before? Fender-bender, jumpstart, ran over something, ???
Old Feb 25, 2017 | 09:59 PM
Check the voltage at the battery. Should be around 12.6v with a full charge.
Next. Check the voltage at the under hood fuse box. Should be the same at both ends.
It has been reported on this site before of folks having a loose or corroded connection at the under hood box and loosing all battery power.
brazor06
Dec 11, 2022 07:59 AM
Pretzel
Oct 3, 2014 10:37 AM
allij0812
Dec 12, 2013 11:16 PM
rendon47
Dec 23, 2011 02:26 PM
da_dad66
2.2L Performance Tech
0
Apr 8, 2008 08:03 PM
