No power on my alternator
Old Feb 18, 2017 | 10:04 PM
rbetance's Avatar
OK, replaced the alternator for a new one and a new battery. The hhr ran perfectly, after running for about 2 hours or so and shutting it off for about 5 minutes the hhr struggled to turn on. When driving it feels like limp mode and the lights flicker quite a bit. After a few hours if I try turn on the car it will turn on fine. Once it warms up and i shut it off it runs like its drained...I'm more confused with this issue???
Old Feb 18, 2017 | 10:13 PM
Could be the positive connection at the starter, or a ground.
Old Feb 18, 2017 | 10:29 PM
Is the Check Engine Light on? If so, you need to download the codes with an OBDII code reader and post the code itself here.
Otherwise, it's time to take it to a shop for a proper diagnosis, before you throw more money into it without resolving anything, or cause further damage. The electrical system in the HHR is not simple like the cars of years ago.
Old Feb 18, 2017 | 10:31 PM
Are you checking the charging system after replacing the parts ?
Sounds like it's still not charging and it's just running till the battery drains down.
Can't just throw parts at it without checking to make sure they're working.
Old Feb 18, 2017 | 10:37 PM
rbetance's Avatar
Whopper, the check engine light isn't on but the dashboard does say low voltage.
Old Feb 19, 2017 | 09:00 AM
aradmahogany's Avatar
so the battery light is on I'm assuming..... Get them tested at local parts store. Then check grounds and connections to whatever part fails the test. If that doesn't work replace the failed part. Done!
Old Feb 19, 2017 | 09:06 AM
I am betting on a loose wire somewhere. You need to find out if the alternator is putting out and just not getting to the battery, or if it is not functioning for some reason. Like the control wires are broken.
All of the ground locations under the hood. https://www.chevyhhr.net/forums/how-...cations-56504/
You might check fuse #16 on the BCM.
Did somebody throw the current sensor near the battery away, thinking it was just a piece of extra stuff? It is on the negative cable at the battery.
Size:  18.6 KB No power on my alternator-charging.png Name:  battneg.PNG
-md- HHR
2.2L Performance Tech
28
Jun 12, 2008 12:57 PM
da_dad66
0
Apr 8, 2008 08:03 PM
JT's HHR
Jan 24, 2008 01:15 AM
upzaw2000
Jan 30, 2007 01:32 AM
Copperhead
Sep 5, 2006 09:44 AM
