No power to the starter
Old Jan 25, 2023 | 03:52 PM
mister hhr's Avatar
2011 2.2 starter won't engage when I turn the key lights horn work it started couple weeks back put new battery in it still got nothing after 3 or 4 try's of turning the key it started fine for a few days then would randomly would just lose power ended up broke down had the car towed home no check engine light
Old Jan 25, 2023 | 04:28 PM
Check all fuses and relays, make sure they are seated tightly in their place, make sure the five 7 mm bolts are tight in the under hood fuse box .
I have to ask, are you sure you put the wires back onto the correct terminals on the starter?
The Original Mechanic: How to replace the starter on a GM 2.2L Ecotec engine in Cobalt, Cavalier, HHR, Malibu and more
Old Jan 25, 2023 | 05:00 PM
“It started fine for a few days”
Well. That sounds like the new battery ran down after a few days of use. Have you checked the voltage in the battery ? Or tried to jump start it ?
Old Jan 25, 2023 | 05:07 PM
mister hhr's Avatar
Have not tried jump start the car
Old Jan 25, 2023 | 05:11 PM
mister hhr's Avatar
I haven't replaced the starter just the battery Ii will check the bolt's you mentioned in the fuse block tomorrow weather permitting
Old Jan 25, 2023 | 06:00 PM
greg8453's Avatar
Start by checking the battery. Until you know you have a good battery (fully charged) you may waste a lot of time.
Old Jan 25, 2023 | 06:10 PM
mister hhr's Avatar
Sounds like a plan thanks for the tip
Old Jan 25, 2023 | 06:12 PM
If the battery did run down that fast the alternator needs looking at.
Old Jan 25, 2023 | 06:24 PM
Maybe the Serpentine Belt is loose... or gone.
Old Jan 25, 2023 | 06:41 PM
mister hhr's Avatar
If the belt was missing wouldn't there be a idiot lite on the dash come on I don't see a amp gauge on the dash ?
