No power to the starter
I Will try to jump start the car see what happens. When I put the new battery in and tried to start the car when I turned the key still did nothing after 3 or 4 try's it started right up I drove it for a week or so I was running errands one day made a right turn at stoplight right rear tire hit a pot hole engine died got it off the road trued to start turned the key got nothing same as before after 3 or 4 try's started up for a few days untill it quit running again only this time no start I'm thinking it's got s wiring issues.
So basically you haven’t looked at or checked anything yet. Not much else we can offer at this point until you at least check some of the suggestions.
I see you’ve been a member here for a long time. Then you should be familiar with the Ignition Recall work mentioned above by RJ RS SS 350.
