No power to the starter
Old Jan 26, 2023 | 06:38 PM
  #31
Does your ignition key have a small round hole? Recall has been done.
Old Jan 26, 2023 | 06:40 PM
  #32
Easy enough to change the ignition switch
Old Jan 26, 2023 | 06:54 PM
  #33
I still suspect the fuses and relays in the under hood fuse panel
Old Jan 26, 2023 | 07:28 PM
  #34
mister hhr's Avatar
I suspect there is a wiring problem causing the issues
Old Jan 26, 2023 | 07:29 PM
  #35
mister hhr's Avatar
I will I have to look
Old Jan 26, 2023 | 07:36 PM
  #36
mister hhr's Avatar
Thanks for the video on the IGN switch
Old Jan 26, 2023 | 10:23 PM
  #37
greg8453's Avatar
What have you actually tested? Anything?
Old Jan 27, 2023 | 08:22 AM
  #38
The ignition switch is a free recall if you still have the oblong hole in the key.
Old Jan 27, 2023 | 06:40 PM
  #39
Wasn’t the ignition recall for the key cylinder assembly and ignition switch
Old Jan 27, 2023 | 06:45 PM
  #40
Wasn’t the ignition recall for the key cylinder assembly?
1st phase was for the key cylinder replacement. Later, the 2nd phase was for the ignition switch and the 2 new keys with the small key ring holes.
