No power to the starter
There are 2 wires under the red plastic cover, one to the battery and the other goes down to the starter. There’s a wire that connects to the power steering, you can see it just to the left .
Loose nut or corrosion is what you are looking for.
Then you need to see if there is power at the other end on the starter. The skinny wire on the starter comes from the starter relay in the fuse box.
I tightened those bolts in the underwood pdc box and cleaned the cable's at the positive remote start charged the battery had it tested it was good 578 cca out of 600 cca total still no start.
