No power to the starter
Old Mar 29, 2023 | 04:22 PM
  #51
mister hhr's Avatar
Originally Posted by donbrew
Those bolts need to be past "afraid something would strip".
The large red wire on the outside of the fuse box comes directly from the battery and directly to the starter.
I noticed that red cable you mentioned looked a little dirty .
Old Mar 29, 2023 | 04:24 PM
  #52
mister hhr's Avatar
Bolts
Ok I'll give em another round of tightening.
Old Mar 29, 2023 | 04:29 PM
  #53
There are 2 wires under the red plastic cover, one to the battery and the other goes down to the starter. There’s a wire that connects to the power steering, you can see it just to the left .
Old Mar 29, 2023 | 06:57 PM
  #54
mister hhr's Avatar
I see them didn't know the one wire was for the power steering the two red wires on mine don't look corroded but they are not shiny either fwiw.
Old Mar 30, 2023 | 08:48 AM
  #55
Loose nut or corrosion is what you are looking for.
Then you need to see if there is power at the other end on the starter. The skinny wire on the starter comes from the starter relay in the fuse box.
Old Mar 30, 2023 | 09:34 AM
  #56
greg8453's Avatar
Looks are not to be relied upon. If there's any question the cable should be taken apart and cleaned and properly tightened.
Old Mar 30, 2023 | 11:22 AM
  #57
mister hhr's Avatar
I will have to try that next I tighten the four bolts in the under hood pdc box also had the battery charged up it tested good
Old Mar 30, 2023 | 03:48 PM
  #58
mister hhr's Avatar
I tightened those bolts in the underwood pdc box and cleaned the cable's at the positive remote start charged the battery had it tested it was good 578 cca out of 600 cca total still no start.
Old Mar 30, 2023 | 04:09 PM
  #59
Time to start swapping relays
Old Mar 30, 2023 | 04:42 PM
  #60
mister hhr's Avatar
Which relay's do I swap?
