No power to the starter
Old Jan 25, 2023 | 06:50 PM
mister hhr's Avatar
Originally Posted by donbrew
If the battery did run down that fast the alternator needs looking at.
I Will try to jump start the car see what happens. When I put the new battery in and tried to start the car when I turned the key still did nothing after 3 or 4 try's it started right up I drove it for a week or so I was running errands one day made a right turn at stoplight right rear tire hit a pot hole engine died got it off the road trued to start turned the key got nothing same as before after 3 or 4 try's started up for a few days untill it quit running again only this time no start I'm thinking it's got s wiring issues.
Old Jan 25, 2023 | 08:35 PM
Seeing as how the battery is in the right rear, maybe you should have somebody inspect the battery terminals. They are very easy to damage and just a little loose can be bad.
Old Jan 25, 2023 | 09:25 PM
mister hhr's Avatar
The battery terminals looked brand new they didn't appear to be loose they tighten up fine I cleaned them with my wire brush but I will check them again
Old Jan 25, 2023 | 10:21 PM
If you checked the battery terminals, then why didn’t you check the battery voltage as was suggested ?
Old Jan 25, 2023 | 10:31 PM
Oh! Have the ignition related recalls been performed?
There's a link in my signature for recall status.
Old Jan 25, 2023 | 10:56 PM
mister hhr's Avatar
I haven't checked anything yet I'm talking about when I installed the new battery everything looked fine and I cleaned the terminal's with a wire brush.
Old Jan 25, 2023 | 10:59 PM
mister hhr's Avatar
WE bought the car used in 2015 there has been no recall work done to it since we have had it.
Old Jan 25, 2023 | 11:08 PM
Ok... so did you check?
Old Jan 25, 2023 | 11:29 PM
mister hhr's Avatar
No I haven't checked
Old Jan 26, 2023 | 07:40 AM
So basically you haven’t looked at or checked anything yet. Not much else we can offer at this point until you at least check some of the suggestions.
I see you’ve been a member here for a long time. Then you should be familiar with the Ignition Recall work mentioned above by RJ RS SS 350.
