no reverse
the other thread has been closed.
Unless you are highly mechanically minded and capable, you are best to take FMG's advice and get it to a transmission repair shop you can trust. Auto trans are quite complex, and the shop should be able to run some diagnostics on it to help pinpoint the problem.
By any chance is the Check Engine Light on?
aboard lox!I'll have to agree with George & whopper, it could be something as simple as failure in the shifter, to a catastrophic failure in the transmission.
In this case, the best advice is Get Thee to a Transmission Shop post haste.
