No sparks when connecting jumper cables
How far are you from a parts palace to have your battery load tested and the charging system tested to confirm the alternator is toast and it may have killed the 4 month old battery?
the battery and cables may look fine , did you check and physically remove and clean the battery terminals? Did you make sure the Maxi fuse is clean and seated correctly and firmly into it’s socket, it powers the BCM
If I was at my shop, I would obviously be using different procedures.... I'm going to edit the main post so I stop seeing these helpful hints.
Yes, it is better to burn your car down 1200 miles from home.
Sorry, didn't know you were a Master Mechanic, not in your profile. A lot of people don't know how dangerous sparks can be. I was stating the fact for all of them that might read this thread and might think it is a smart way to do the job.
TLDR: It was the starter.
WHen connecting the jumper cables to the jump post/ground, the lack of sparks indicated the current wasn't traveling freely along it's intended route.
I called a buddy with a voltmeter and we tested the wiring and fuses from the posts to battery to starter and back to posts. Wasn't getting any readings at the starter itself. Disconnected it, took it to O'Reilly's. They tested it. It's bad.
The main reason for needing the starter working, aside from the obvious ones, was to be able to turn the engine over and diagnose all the other issues that sprang up.
I'll start a new thread on that. I just wanted to close out this one by stating a solution was found.
There might be a problem with the alternator. It was dying the previous night while I was driving, but what was weird about that was it wouldn't die until I put it in neutral to coast down a hill. Luckily there were enough hills to get me home, but I meant that I had to start it that many times. I finally died on me in the driveway.
Seemed to charge fine the next morning. Right up until it died on me about mile and half up the road. Maybe it was because I was trying to jump it at night that I noticed it wasn't getting any sparks.
Smuffy
Jul 7, 2014 03:39 AM
