No temp indication or a/c
I have a 2008 hhr I bought new. Not many problems other than at about 90,000 miles the analog and digital temp indicator would go out and no a/c. Initially this problem was intermitent. Now most of time. I've replace thermostat and the coolant temp sensor. Any ideas ??? HELP !!!!
Make sure you have coolant. Open the pressure cap when cold, the coolant should come up to the top of the hose. The classic diagnosis is t-stat, but at 90K you may be getting into head gasket trouble.
rawhidesr33
Maintenance and Upkeep
Jun 11, 2015 09:16 PM
