how do I change oil indication on information panel?
Old Jun 11, 2015 | 06:21 PM
rawhidesr33's Avatar
Unhappy how do I change oil indication on information panel?
need to know how to change the information panel oil change indicator? any help?
Old Jun 11, 2015 | 06:26 PM
Welcome to the site, I turn the ignition key to run but don't start the engine then press the accelerator pedal three times. Turn the key back to remove the key.
Old Jun 11, 2015 | 07:43 PM
Reading the owners manual would be a good start as well - manuals can be downloaded here: https://www.chevyhhr.net/forums/gene...s-manual-3074/
Old Jun 11, 2015 | 08:03 PM
Yeah Oldblue. Take the short cut.
Actually, SS owners like me can't use the "3 tap" method. Apparently the GM guru's didn't put that method in the SS's programming. Go figure.
Old Jun 11, 2015 | 08:08 PM
This is not a how-to, so it's been moved to maintenance & upkeep.
Welcome!
Old Jun 11, 2015 | 09:16 PM
manicrodder's Avatar
Welcome!
JWA
16
Jun 21, 2014 12:16 PM
badassbowtie
Maintenance and Upkeep
23
May 12, 2013 02:01 PM
easehnert
Apr 10, 2013 05:36 PM
refowler
18
Mar 1, 2012 01:43 PM
